dodge heated mirrors
Old Dec 26, 2012 | 06:18 PM
dodgeit54's Avatar
dodgeit54
Default dodge heated mirrors
i have a 2006 dodge ram 2500 , it has heated mirrors and the button to turn them on is blinking and the mirrors are not heating, i have checked the fuses and they are ok. what dose the blinking light mean
Old Dec 27, 2012 | 12:05 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
defective ac/heating control panel
I have several if you are interested or check on ebay
Old Dec 27, 2012 | 12:47 AM
66three83's Avatar
66three83
Mine would blink after my recirc door broke. The hvac panel was not defective, the system goes through a check every 10 or 20 starts, and if a actuator motor spins freely, it will trip the flashing light which, unfortunately, renders the heated mirror button inoperative. After I replaced the recirc door last year, I have had no problems. Best to check that door first as it's the easiest to get to.
Old Dec 30, 2012 | 12:24 PM
inktoxicated's Avatar
inktoxicated
since were talkn bout mirros i was looking to get the tow mirros. i have power mirrors that have the lil heat sign on them but i have no switch in truck for heat. are mine not heat? do i still buy power/heat tow or manual?
edit nevermind i found another post that answer my question
Solid Rear Window-available with defrost or no defrost.
Sliding Rear Window-avaliable with no defrost only.
If you have the defrost button on your HVAC control panel and you have the sliding window, then the defrost is just for the mirrors.
