3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
when i have my 08 ram in 4h and i feel it engage it drives fine forward and reverse but when i crank the wheel 90 degrees or more when turning it locks up and stops my truck.
That's why you should not use 4wd on dry ground. Especially if you make a sharp turn. It puts tremendous pressure on your front drive train. If you're in 4wd on dry pavement, keep the turns as wide as you can, better yet don't use it unless you're on slippery ground.
Completely normal as mentioned. It has something to do with the universal joints when they have power going to them if I'm not mistaken.
In any case, do NOT use 4x4 on dry ground or where the wheels are not allowed to slip.
Read up on "driveline windup".
Exactly!
Do not give it more gas until the tires slip, that pressure has to release somewhere...hopefully at the end of the line with a chirping tire, but it could be at the CV joint, ring and pinion, drive shaft, transfer case....etc!
