05 engine swap
Old Jan 2, 2013 | 09:57 PM
01BlAcKsPoRt's Avatar
01BlAcKsPoRt
Default 05 engine swap
So I bought an 05 ram 4.7 slt with a blown engine. I bought another engine with only 65,000 from a wrecked Dakota. I was told it was the same. Anyways after swapping in the engine I tried to start it, and BOOM!!!, the air filter box blew up. I talked to the guy that sold me the engine, he's an old friend, and promises that the engine was running great when it was in the other truck. But now it tries to start but it won't. I know it has fuel and spark.
Any suggestions will be appreciated.
Thanks in advance.
Old Jan 2, 2013 | 10:13 PM
DanielHemi's Avatar
DanielHemi
Try checking the timing, make sure the cams are correct and then look at the firing order of the spark plugs, they may be scrambled, or the fuel injector's wiring may be scrambled. If the air box got the big kaboom, a valve may be open when the spark plug fires.
Hope that gives you somewhere helpful to start.
Don't worry, if you can do a swap, you will figure this out.
Old Jan 2, 2013 | 10:27 PM
T-Muns's Avatar
T-Muns
What year was the Dakota?
Old Jan 3, 2013 | 09:20 AM
01BlAcKsPoRt
Engine is from a 2006 Dakota.
Old Jan 3, 2013 | 06:58 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Im not a 4.7 man myself but check with Hammer. He had one in his Jeep I think.
Old Jan 4, 2013 | 07:07 PM
01BlAcKsPoRt
I checked for codes but none came up. I changed the cam position sensor, and nothing. But now with the new cps, code p0340 (cam sensor) is appearing on my scanner. I reset the computer and the code comes back after cranking.
Old Jan 5, 2013 | 04:48 AM
HemiLonestar's Avatar
HemiLonestar
Sounds like the 07 engine may have an incorrect (for your 05 computer) tooth tone wheel?
Old Jan 6, 2013 | 11:03 PM
01BlAcKsPoRt
What is a "tooth tone wheel"?
Old Jan 8, 2013 | 12:21 AM
HemiLonestar
Incorrect tooth tone wheel. As in your tone wheel has the wrong number of teeth on it.
Old Jan 8, 2013 | 08:26 AM
01BlAcKsPoRt
If I get the correct computer for the engine, could I just swap it out? Or is the wiring harness and pin locations different for each engine?
