Please Advise:
2006 Dodge Ram 1500 5.7 Hemi 2wd 176,400 miles
I've noticed since around 130,000 or so miles, my truck doesnt seem as "strong" as it has been. I have to really put the pedal in the floor when I wanna pass someone on the highway. It'll get up & go, just not like it used to.
I've always changed my fluids regularly. I'm not going to lie & tell you I change my spark plugs every 30,000, but my current plugs have probably 20,000 miles or so on them. Is there anything else I should be doing or any sort of "tune up" I can do to give my truck back its "pep"
Thanks,
McNasy
Thanks,
McNasy
your spark plugs should be copper core so they should be replaced somewhere between 10k-15k... at least thats when I do mine. 20k is pushing them a bit.
If you don't see an improvement with the plugs changed, have a compression test done and see if you've got a weak cylinder...
Also a lot of that "pep" comes from the transmission too, so you should give that a good once over..
Definitely check the tranny too. If you haven't flushed out the fluid from there do that too as well as the Diff oil. Almost 180k on the original tranny is alot. It could be time for a rebuild possibly too. Are the shifts smooth or kinda jerky/harsh?
Trending Topics
Definitely why I suggested he have the compression test done... just to be on the safe side.
