radiator fan goes on together with ignition in cold weather
Old Jan 28, 2013 | 07:18 PM
MoparMan1991's Avatar
MoparMan1991
Originally Posted by MikeHTally
If you take a moment while visiting your neighborhood Dodge dealer, try to turn the fan with the motor off. It will definitely spin, so the clutch is most assuredly disengaged when the motor is cold. When the motor is cold, why would there be any need for cooling?
No matter what the fan will always spin. Even a disengaged fan will spin. If your fan spins freely for more than 1/4 of a turn when the motor is off, you have a bad fan clutch. If it doesn't spin at all of if the blade wobbles front to back you have a bad fan clutch, or a water pump.
Maybe it's the whole centrifugal force thing.
Old Jan 29, 2013 | 01:06 AM
SteveCZ28's Avatar
SteveCZ28
Originally Posted by MoparMan1991
The radiator fan.
Mechanical or Electric?
rad fan, mechanical belt driven
Old Jan 29, 2013 | 01:53 AM
MoparMan1991
In some instances there is a small electric fan generally used for transmission cooling or emergency engine cooling. It is a smaller radiator, but a radiator nonetheless, which is why I keep wanting that clarified.
