Old Aug 6, 2015, 12:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
headlights stayed on after i shut them off
Old Jan 31, 2013 | 04:55 PM
Izero's Avatar
Izero
Originally Posted by swamper
ok well my lights dont stay on for a min after i shut them off at all the go right off.they never have .seeing i bought the truck used if its suppose to do this maybe its broken.
That is because you have a 2002.... I think it is only 2005+ possibly only 2006+, because of the TIPM system...
Old Jan 31, 2013 | 05:00 PM
Kscha41's Avatar
Kscha41
It worked on my 04.
Old Jan 31, 2013 | 05:10 PM
Chase Lejeune's Avatar
Chase Lejeune
works on '05
dersu's Avatar
dersu
My 2002 does it. Turn of the key with the lights on, they stay on even when the switch is shut off. For a minute or so. Scared the hell out of me the first time I did it by accident.
Old Jan 31, 2013 | 05:13 PM
Izero's Avatar
Izero
Then might just be a convenience option?
Where is Dodge Cares when you need them? lol
Old Jan 31, 2013 | 05:19 PM
Chase Lejeune
second that ^
also, OP, what package(s) do you have on your ram? mine has the SLT
i suggest requesting a build sheet. tells you almost everything about your vehicle.
Old Jan 31, 2013 | 06:49 PM
GRNDPNDR's Avatar
GRNDPNDR
mine also. For the first week or two that I owned the truck I had to keep going back and checking if my lights were turned off.
Since I was randomly shutting off the engine and the lights, it didn't always happen and I was confused.....
It was literally like 3 weeks ago that I learned how they actually work.
I also learned how to turn off horn chirp when setting the alarm, which is good since I recently installed air horns and was in the habit of setting the alarm when I was directly in front of the grill.....
I no longer startle myself or hear that annoying ringing in my ears
Are you going to answer that?
Old Feb 1, 2013 | 10:42 AM
DodgeCares's Avatar
DodgeCares
On the 2002 1500 they are supposed to work this way:
If you turn off the headlights, then the vehicle, the lights should stay off. If you turn the ignition switch to the off position then turn the headlight switch to the off position, the headlights should stay on for a minute or so, then go out.
Old Feb 1, 2013 | 02:19 PM
Jlaza's Avatar
Jlaza
I have a 2003 and it does it
Old Feb 2, 2013 | 03:08 PM
Plainbroke's Avatar
Plainbroke
Exactly how mine work too. and it is an 02.
