Help! Overhead console swap in 06 ram from OTIS to EVIC
Old Feb 21, 2013 | 07:57 AM
DodgeCares's Avatar
DodgeCares
Question is will it work? I do not show either being available on the ST models. Being that the vehicle listed in your profile is a TRX I am guessing you have an ST model since those are the models the TRX was an option on? What I am trying to say is that if you do have an ST model, since it was not an option on your vehicle I do not know if it will even work or be able to be programmed in to work. Programming a sales code into a vehicle that was not available with a choice of that option often cannot be done. You are using a 2500 or 3500 SLT or Laramie to say it should work on a 1500 ST because they are the same year, but they didn't have the same options. If you get me a vin that has the option you are looking for I will get you a part number, but I cannot tell you if you will be able to get it to work.
Old Feb 21, 2013 | 08:11 AM
JoshuaAckley's Avatar
JoshuaAckley
That's the $100 question. My truck is an SLT, with the TRX4 offroad package. Not the ST model. I will try to get you a vin. Still whether 1500, 2500, or 3500, no matter what trim, I have not been able to find more than two overhead electronic modules, one with garage door opener, and one without.
Joshua
Old Feb 21, 2013 | 08:24 AM
DodgeCares's Avatar
DodgeCares
It may have been a late availability option. The sales code guides I have from back then are the last one for the model year so I cannot see if it was available the entire year. PM me your vin and I will see if the overhead is listed as available in the parts catalog. If it is not, then I would need a vin that does have it to be able to look up the exact part number for what you are looking for.
Old Feb 21, 2013 | 08:41 AM
DodgeCares's Avatar
DodgeCares
For 2006 the part numbers I came up with are as follows:
56049824AD W/O garage door opener
56044864AD With garage door opener
I show it being listed as a module. I am sure you can Google these part numbers to see if they are what you need but I put these out there with the following disclaimer that in no way am I suggesting they will work for the mod you are attempting.
Old Feb 22, 2013 | 12:01 AM
JoshuaAckley
Both of those at the regular OTIS. I have the one without the garage door opener. Guess I'll just have to go to the dealer and have them hook it up to the starscan tool.
