35's to 37's ?? tires??
Old Feb 10, 2013 | 06:15 PM
PhillyFireLieutenant's Avatar
Default 35's to 37's ?? tires??
thinking of making the jump for the next set of tires,, i know there is a general thought that you can safely run 35's with stock drive train, i have no problems with them the last 3 years,,
what needs to be done if i wanna move up to 37's??? anybody running them (pics)??
Old Feb 11, 2013 | 07:37 AM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
I know that the big things discussed on here were both the IFS parts and gearing which could eventually damage the transmission from overworking it due to the rolling weight of the tires. I think the biggest issue is the front suspension, and since you have a SFA, you pretty much negate most of that.
Old Feb 11, 2013 | 08:16 AM
08HEMI1500's Avatar
08HEMI1500
Yep with SFA you can run 37s with no real problems. Might want to start thinking about re-gearing though
Old Feb 12, 2013 | 09:21 AM
Question thanx guys. (gearing?)
thanx for the info,, on the solid front axle of the mega cab,, as far as gearing, i imagine the stock gearing must be a 3:73?,
and if i re-gear, i have to do it to the rear and front (pumpkins) correct?
what is the common next gear up? 3:90's or 4:11"s?
Old Feb 12, 2013 | 01:47 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive been running 36s for years with no issues
Old Feb 12, 2013 | 03:59 PM
08HEMI1500's Avatar
08HEMI1500
Yes both diffs would have to be re-geared. The gearing really depends on what you use the truck for. If you're going to be off road and not much highway I would suggest 4.56s. With 3.92s or 4.10s (or whatever the equivalent is for HDs) you won't notice any real difference the justify the cost
Old Feb 12, 2013 | 04:11 PM
Default thanx "weed" an 08hemi1500
thanx guys will see what the tax return yields,$$,, and will post up results..,,,,,weed I may try to keep the oem gearing, but knock on wood,, with 65k an only putting front an rear brakes on thru out the years, I don't wanna push it,, may throw sum 4:10's on it,, mainly ride over the deep sand,, but 98% street truck.
Old Feb 12, 2013 | 04:16 PM
Default good info
good info,,thanx
Old Feb 16, 2013 | 01:07 PM
RamLussier's Avatar
RamLussier
Were you driving 35's without lift kit?
