MDS v8 to 4cyl
MDS v8 to 4cyl
I've searched the forum a couple of time and I don't see my answer.
My 2007 Ram 1500 5.7 Hemi stay in 8 cyl. I think there is a problem with my MDS. The truck suppose to drop on 4 cyl but he is not doing it anymore. Is there a sensor, a relay, a solenoid or something like that can be defect? Very expensive on gas right now.
Now that we know what size wheels you have, what size tires do you have?
If they are larger than stock, this may cause less MDS activation (just another piece of the puzzle)
Trending Topics
Just bring it in to the dealer and have them give it a road test while logging it.
I know there were a whole bunch of MDS updates that Dodge made to the programming, so you might just need a re-flash on the system...
If you used a programmer you can expect to see less MDS activation too....
What other modifications have you done to your truck? (if any)
Are you using the recommended oil viscosity?
SAE VISCOSITY
An SAE viscosity grade is used to specify the viscosity of engine oil. Use only engine oils with multiple viscosities such as 5W-20 or 5W-30. These are specified with a dual SAE viscosity grade which indicates the cold-to-hot temperature viscosity range. Select an engine oil that is best suited to your particular temperature range and variation. For 3.7L/4.7L engines SAE 5W-20 engine oil is recommended for all operating temperatures. For 5.7L engines SAE 5W-20 engine oil is recommended for all operating temperatures.These engine oils improve low temperature starting and vehicle fuel economy. Refer to your engine oil filler cap for the recommended engine oil viscosity for your vehicle. Vehicles with 5.7L engines equipped with Multiple Displacement System (MDS) must use SAE 5W-20 oil. Failure to do so may result in improper operation of the Multiple Displacement System (MDS). Refer to Multi Displacement System under Starting and Operating for details. Refer to the engine oil filler cap for the recommened engine oil viscosity for each vehicle.
SAE VISCOSITY
SAE VISCOSITY
Good point there buddy, I didn't even think about the engine oil! Nice Call!
