Pacesetter Headers on my 04 ram 2500 hemi?
If you need to replace the oem manifolds and ex pipes, than headers and a true dual ex will improve performance. In my case, I replaced a perfectly good singel oem ex on my 2500.
Performance and flue economy did improve with y pipe removal and two 2.5 in mufflers, mangnaflow, ultra flow and dynomax, ultra flow x muffler) all are garbage, they souned great but with in a year I was blowing out the packing on the dynomax, and the rear seams on the mangnaflows and ultra flows..
The dumb *** who did the converison welded a rod to the pipes and attached to the factery hangers, now the welds have rotted out leaving holes in the whole system.
In hindsight, using a muffler clamp and welding a rod to the clamp makes more sense.
I have not found a cat back kit for a 2500 hemi using two 2.5 muffler or mufflers, their are kits using a singel in and dual out.
On this go arround, Im running two cherry bomb glass packs, 29 in long, when the packing is toast in the mufflers, Im just going to leave the mufflers in place, vers screwing arround again with with free flowing canister style or chamber mufflers ..
I still need to figure out how to run two ex pipes over the rear diff and stright out the left rear, their are kits on line, jegs, ebay, summit that are prebent mandrel pipes that you can modify.
My intila point is that if if aint broke, leave as is..
its simple to cut out the y pipe and thiers room for two mufflers side by side or run one muffler with two inlets and two out lets, tricky part is fabricating pipe over the rear diff, I'm not running pipe arround the spare , booth pipes are going stright out the right rear like a srt10 ram.
if you tow a trailer my configuration will add ex residue on your trailer, but I can live with it.
I doubt a lift kit is going to help as you want the ex system tucked as close to the frame as possible for off road use.. you dont want to sucking in water or mud threw your mufflers + tailil pipes and you don't want to be starting fires with hot ex.
A body lift kit would give you more clearance for headers, but Im not installing headers, so this is a area I have nothing practical to offer.
I considerd running dumps off the mufflers or running two pipes out before the left rear wheel but this is not practical for making my own trails off the off road trail!!
Anothier reason why Im going to glass packs, is thier stright flow design and smaller cassing, less chance of rotting or rusting out the seams on the mufflers I have cooked in the past..
Thiers plenty of room to run pipes and two mufflers on a stock hemi 2500 and two 2.5 in pipes over the rear diff.
When I have new 2.5 in pipes from the cats back and the two cherry bombs installed, I will see what a muffler shop can do for the rear pipes, or I will fab up the pipes and cut with my chop saw and than have them welded up..
Summit racing has 2.5 dual kits with no mufflers that offer the abillity to custom build, living in the great white north, the cost to ship it is equal to the kits price...
well i think ill just have to get under the truck and see what i am working with haha. Yea I get what you mean that its going to be tough to fab it up to fit close to the frame. Do you think getting rid of the spare would be ok? May not be a great idea bit it could allow for more room. I honestly would never take my truck off roading I baby it way too much but.
Cyclone429 if you could send me your email I would like to give you updates on how everything is going for me with the exhaust when i get around to doing it. Probly wont be until the summer when im out of school
And this is just single exhaust
before(tailpipe hitting leafs)
after
If your looking for headers for your power wagons check out AMERICAN RACING HEADERS. They have a kit for the 2500-3500 rams that will bolt right up and bring our big trucks right to life!!!So I talked to Nick at ARH and they dont have a part number yet for the system but if you call they have them instock
I copied this from another site...I'm not sure how accurate it is
