Radio mutes itself at random
Old Mar 16, 2013 | 07:52 PM
Jrskihog's Avatar
Jrskihog
Default Radio mutes itself at random
I have the infinitely sound system 02 QC and the radio slowly turns itself down to mute. Sometimes it works for 15 mins other times it only works 1,2,4, or 5 mins. I can't find anyone else with this problem and can't figure out what is causing this any suggestions? TIA
Old Mar 17, 2013 | 03:02 PM
04HemiGreg's Avatar
04HemiGreg
Not sure, but if want to try swapping out the head unit, i have the RAZ (cd and cassette) unit that came out of my truck i am looking to sell. I have the infinity sound in mine also.
Old Mar 18, 2013 | 08:57 AM
Izero's Avatar
Izero
does this happen when you slow down? or is it completely random independent of speed?
Do you have steering wheel controls for volume?
I've seen this a few times on other Chrysler & Jeep vehicles, and it usually turned out to be either a shorted steering wheel control, or a radio speed sensor that was not working right.
On a few I can remember that it was the infinity amp that just took a dump and lost power....
I suggest you check the incoming power to the Amp, if it fluctuates too much or has a high and low amp draw then it's likely the problem.
You can find those amps reasonably priced online...
Old Mar 20, 2013 | 03:18 PM
Jrskihog's Avatar
Jrskihog
It happens at random speeds and when in park. Sometimes it will do it if you stop fast. I don't have steering wheel controls. I'll have to check the amp draw. When the weather breaks luckily it isn't a DD.
Old Mar 20, 2013 | 03:56 PM
Izero's Avatar
Izero
Definitely let us know.... You may want to also check the voltage off of the battery while the truck is running. Cig Lighter is perfect place to put a tester b/c it is very close to the radio circuit.
Also check if the same thing happens with other inputs.
Meaning Does this also happen when you have A CD/Tape in?
If you have an aux input test audio with that as well.
If it only happens with the AM/FM radio then we're narrowed down a bit.
