need some help brand new truck shakes
Hey guys and girls, this is my first post in an awsome forum packed to the gills with information. You guys seem to know your stuff so I figure i will ask here befor i go to the dealer tomorrow with the problem. Here it is........ My truck shakes back and forth pretty badly above 65 miles per hour. This is my first big truck and I have a 2005 ram hemi with the 20" tires. Is this a common thing because of the tire size. When I let go of the wheel the truck tracks just fine in a straight line just has a bad shimmy to it where you can see my hole arm vibrating when I hold the wheel. It is even worse in the passenger seat. I hope you all dont scare me to bad with what kind of problem it may be. I was thinking maybe a tire out of balance, I checked air pressure and it was all ok. Help my if you can thanks and have a great day!!!!!!!!!
ORIGINAL: bigcmcdannel
I had a friend with the same problem on his ram, and ended up being the rims were bad from the factory. So i do beleive that there are a couple bad sets of 20"s out there. this might help
thanks guys, I appreciate the help!!! I will let you know how it turns out!!!
Trending Topics
If you only have 7 miles on it you must have noticed it on the way home from the dealer, unless you live across the street. You should of turned around and took it back right away!!![sm=chairshot.gif]
