My rpm gauge will sometimes go 100?
Old Apr 6, 2013 | 08:51 PM
vikingdiesel's Avatar
vikingdiesel
Default My rpm gauge will sometimes go 100?
The truck runs and idles good but sometimes it will occssionaly drop down to 100rpm, anyone have this issue before?
Old Apr 13, 2013 | 12:54 AM
go-part's Avatar
go-part
Former Vendor
When exactly does it drop down that low? (Braking, accelerating, turning)
Old Apr 13, 2013 | 12:32 PM
66three83's Avatar
66three83
Mine does too. Drops to around 100 at idle. Been doing that about a year. I'm pretty sure it requires replacing the cluster. I'm not interested in spending $800 for that. Tach works fine otherwise. It's just at idle.
Old Apr 16, 2013 | 01:16 AM
dakotatrevor's Avatar
dakotatrevor
Yup, its the cluster.
It seems to be only an 06 thing. I've tried removing my cluster and re-flowing some solder as others have suggested but it didn't fix it for very long.
Old Apr 16, 2013 | 01:29 AM
vikingdiesel
It help when sitting at a red light, it so when i start braking and coming to a red light it will go to normal idle and then a few seconds later while im still at the red light, it will drop to 400rpm and then go to 100rpm until obviously it turns green and I start moving again, then its all back to normal
Old Apr 16, 2013 | 06:23 PM
lxman1's Avatar
lxman1
Site Moderator
Just the tach or the actual rpm of the engine?
Old Apr 18, 2013 | 02:06 AM
vikingdiesel
just the tach
Old Apr 18, 2013 | 09:56 AM
Izero's Avatar
Izero
so what does it matter then? I wouldn't concern myself if it isn't affecting the performance of the truck.
Old Apr 19, 2013 | 01:32 PM
lxman1's Avatar
lxman1
Site Moderator
It is either the cluster or PCM in that case I would think. I would guess cluster.
