Back Up Horn
Old Apr 12, 2013 | 02:28 PM
dripdodger's Avatar
dripdodger
Default Back Up Horn
I took my 2005 D3500 4x4 to the Dodge dealer. They said there was a recall update that needed to be done. It was to activate the horn if the door is open & you are in reverse. My guess is some dip**** fell out of his truck & got ran over. Some POS lawyer decided theres a lawsuit. How do I disable that damned thing. Any Help appreciated. Drip
Old Apr 13, 2013 | 07:53 PM
jasonw's Avatar
jasonw
Site Moderator
If it was an "update" then that means they put it in the computer, and there might not be a a way to disable it.
Also, for future reference:
https://dodgeforum.com/forum/dodge-r...s-section.html
Old Apr 14, 2013 | 12:27 AM
eng18ine's Avatar
eng18ine
you could always install an aftermarket horn and just disconnect the horn and reconnect it to a different circuit that you make. or disable your reverse switch. but then you wont really have reverse lights.
Old Apr 15, 2013 | 12:34 PM
demon runner's Avatar
demon runner
The only way you can reverse it is to install a new computer (BCM or TIPM I don't remember which) that does not have that programmed into it yet and do not have the recall done Good luck!
