3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Got a 2006 dodge ram 2500,4x4,hemi with the 5 speed automatic. I only have 41,000 miles on it.today I changed the filters but it is doing the same thing. Anybody have any suggestion or ideas before I have to take it to a transmission shop?? Thanks Rick
When I put it in drive, it goes like normal. 1st gear then second. When it is changing to 3rd, the transmission disengages and the engine just revs. If I put the gear selector back from drive to 2nd it engages. reverse is fine.
I didn't drive far when it happened. as soon as the engine started revving. I pulled over. When I realized that 3rd gear was not engaging. I left it in 2nd gear and drove home. I was less than 2 miles in second gear.
Fluid level was good before it happened and is fine since i did the filters. I just sucks that I only have 41,000 miles and never towed or carried anything heavy.
That is a shame. Mine tows a utility trailer from time to time. Max GCWR has been ~13,000#. The PO towed a two-horse trailer (a LOT - 86K in four years). I did a drop 'n' drain after I bought it. Now at 121K - No tranny issues in all that time. Hope you get it figured out.
