Half-shaft bearing surface Ok?
Old Apr 15, 2013 | 11:14 PM
bohicarico's Avatar
bohicarico
Default Half-shaft bearing surface Ok?
Recently, my RH-front hub bearing failed. My steering knuckle was damaged in the process. In the interest of keeping parts costs down, I want to reuse my half-shaft. The bearing surface is a bit rough. However, I think I can sand this down a bit to make it work.
I'd appreciate some feedback, pro or con, either way.
Old Apr 16, 2013 | 07:56 AM
p38251's Avatar
p38251
The bearing does not ride that far back. You can just use some emery cloth to clean that up.
Old Apr 16, 2013 | 11:29 PM
bohicarico's Avatar
bohicarico
Awesome, thanks for lending your critical eyeballs!
