Dumb torsion bar question....
Old Sep 21, 2005 | 04:13 PM
kingaling1986's Avatar
kingaling1986
Default RE: Dumb torsion bar question....
Did turning them up that much change the way it rode? I'm thinking of doing the same, but don't want to change the way it rides.
Thanks,
Jen
Old Sep 21, 2005 | 06:55 PM
Alienfog's Avatar
Alienfog
I have a 2004 QC 2X4. Will I be able to do this with my truck? I too am new to trucks.
Old Sep 22, 2005 | 06:46 PM
hemiyellow's Avatar
hemiyellow
DC Insider
the new 04 rams dont have the torsion bar set up in them, i dont believe on the 4x2 versions anyways. just the 4x4's as far as i know
Old Sep 22, 2005 | 08:11 PM
Alienfog's Avatar
Alienfog
ORIGINAL: hemiyellow
Thanks for the info! So this means I'll have to go with a body lift or suspension lift right?
Old Sep 22, 2005 | 11:20 PM
osteodoc08's Avatar
osteodoc08
The 4x4 uses torsion bars. The 2wd has coil springs. You can get a coil spring spacer for the 2wd truck. Those that have torsion bars can crank them, although that has been known to possible wear things out prematurely by changing the drive angles.
Old Sep 22, 2005 | 11:46 PM
PyRoHAvoC's Avatar
PyRoHAvoC
http://www.truckxpressions.com/truck...eling_kit.html
Old Sep 23, 2005 | 09:28 PM
hemiyellow's Avatar
hemiyellow
DC Insider
i'm just wondering, but why in the world would u want to life a 4x2 truck?????? seems kinda pointless to me, but just wondering what your thoughts are on that.
Old Oct 2, 2005 | 12:24 PM
aviator's Avatar
aviator
When I did mine I ended up turning my right side a bit more than the left. After about a week of driving they changed again, but finally settled. The ride is definitely rougher, especially going over speed bumps, potholes, etc. To change the ride back to stock you need longer shocks. The 98 (I think)-01 factory shocks are 2 inches longer than the 02+ and will bolt right up.
