head gasket help
Old Apr 21, 2013 | 08:36 PM
edamron's Avatar
edamron
Default head gasket help
hi guys in my last post ( https://dodgeforum.com/forum/3rd-gen...ight-help.html ) we found the problem with the truck a 2004 4.7L Ram 1500 SLT. it had water in cylinder 1. now im going to change the gasket, should i change both gasket or just the one in cylinders 1, 3, 5, 7?
also if you have any links or videos that can help me with this job ill be grateful
Old Apr 21, 2013 | 09:06 PM
chevynomor's Avatar
chevynomor
New Member
I have the same problem with my 02 4.7.i thinking of droping in aa 03 hemi just cause i have it.any info would help.maybe i don't wana swap the motor?I'm no Mr.goodwrench. help
Old Apr 21, 2013 | 09:49 PM
rtmtrrdr's Avatar
rtmtrrdr
yes change both sides while you have it apart. Chances are the other side might be bad also or soon to be. I'd also have the heads check while you have it apart anyways.the 4.7 heads don't like to get hot
Old Apr 21, 2013 | 10:26 PM
edamron's Avatar
edamron
any particular recommendation for the gasket brand and material.
