I'm new and I have a question
Old Apr 22, 2013 | 01:29 PM
necci29's Avatar
necci29
Unhappy I'm new and I have a question
Hi, I'm Paula and I have a question about my truck. I have a 2007 Ram 1500 in wonderful condition, but about a month ago the passenger side door would not unlock. You could pull the inside door handle up and open the door but as soon as you let go of the handle the door would lock back. After about a week it just started working again but after a few days it began to make a squealing noise when it locks. Does anyone have any ideas about what might be wrong?????
Old Apr 22, 2013 | 03:51 PM
Hello and welcome to DF! I will move this to the 3rd gen Ram section. You'll get answers there. Welcome aboard!
Old Apr 22, 2013 | 04:30 PM
Izero's Avatar
Izero
Do you have power door locks?
Do you happen to have a video of this happening? As it will be hard to help without seeing what you mean.
Old Apr 23, 2013 | 08:47 AM
DodgeCares's Avatar
DodgeCares
Paula,
My initial thoughts would be a shorted or loose wire going to the lock motor or the lock motor itself going bad.
Old Apr 23, 2013 | 03:05 PM
cuda19791's Avatar
cuda19791
Sounds like a short in a wire gong to the pass side door lock actuator or a bad door lock switch. If it is making noise then it will need replaced but you should fix the problem before you replace the actuator.
Old Apr 25, 2013 | 10:43 AM
necci29's Avatar
necci29
Default door lock
Izero
Yes I have power door locks but I do not have a video of this.
Cuda19791
So I need to replace the door lock switch? Is it in the door panel?
Old Apr 25, 2013 | 11:06 AM
Izero's Avatar
Izero
You might just need to replace the switch... see if it happens when you unplug the door lock switch on the passenger side door.
If it does then it might be the drivers side.
Those kinds of problems are really hard to diagnose without getting to take a look in person.
Old Apr 25, 2013 | 11:25 AM
rtmtrrdr's Avatar
rtmtrrdr
It's either a 10-15 mm wrench. I can't remember off the top of my head.dang dude you dug up an old thread
Old Apr 25, 2013 | 01:11 PM
cuda19791's Avatar
cuda19791
Izero
Cuda19791
Yes it could be the pass side door lock switch or it could be a short in a wire. If I were you I would get somebody who knows how to track down the problem. But If you do try to replace the switch your self be careful removing your switch it is easy to break things if you are not sure how to them apart.
Old Apr 25, 2013 | 01:49 PM
lxman1's Avatar
lxman1
Site Moderator
I agree, could be the actuator is bad (more than likely), a damaged wire in the loom between the body and the door, or a bad switch.
