Gasket, or something Cracked, Oil in Radiator and Coolant in Cylinder
Old Apr 26, 2013 | 10:33 PM
rexbelleville's Avatar
rexbelleville
Default Gasket, or something Cracked, Oil in Radiator and Coolant in Cylinder
I just bought a broken Dodge Ram 1500 3.7L and there is oil in the radiator and coolant in one or two cylinders. Is it most likely a gasket, cracked head or block? Anybody? Please help....Thanks!! 11 secs ago
Old Apr 27, 2013 | 02:04 AM
jasonw's Avatar
jasonw
Site Moderator
For future reference:
https://dodgeforum.com/forum/dodge-r...s-section.html
Old Apr 27, 2013 | 08:17 AM
Gone Fishin's Avatar
Gone Fishin
You're probably right on the mark, time to start pulling it apart--at least down to the heads to fully diagnose. Might want to do some prelim work like a compression check nd such. Oil in the antifreeze is never a good thing, but doesn't necessarily indicate a cracked head either, could just be a bad head or intake gasket.
Old Apr 27, 2013 | 05:20 PM
rexbelleville
thanks, if I drain the radiator then put new oil in it and fire it up it runs fine but as soon as I start filling the radiator it starts having problems and eventually won't run anymore. I hope it is just a head gasket...
Old Apr 27, 2013 | 09:31 PM
HammerZ71's Avatar
HammerZ71
Could be warped or cracked heads, but most likely just the gasket. Cheap part, long time to replace... Been there, done that on a 4.7...
Old Apr 28, 2013 | 04:18 PM
lxman1's Avatar
lxman1
Site Moderator
I would remove the heads, have a machine shop magnaflux them to check for cracks and have them checked for warpage. If all is good, clean everything up and reinstall them.
