Running No Front Shocks?
Old Apr 27, 2013 | 09:15 PM
team_realtree's Avatar
team_realtree
Default Running No Front Shocks?
This might sound crazy but how bad would it be to run no front shocks for a couple weeks just straight coil springs on a 2wd ram 1500? I had to remove my Monroe shocks and of course the upper shock mount had essentially welded itself together from rust so I cut them off. Locally I can only get the same Monroe shocks but because I'm lifted I want to get pro comp es9000's. Because of my big coil spacer the coil spring is not nearly as bouncy and I drove it like that all day. It rode better than with the maxed out Monroe's.
Old Apr 28, 2013 | 12:14 AM
stewie01's Avatar
stewie01
If you keep on smooth pavement and avoid pot holes it should probably be alright.
Old Apr 28, 2013 | 08:46 AM
MikeHTally's Avatar
MikeHTally
It'll certainly be bouncy. You won't have a lot of control, either.
Old Apr 28, 2013 | 09:05 AM
rtmtrrdr's Avatar
rtmtrrdr
If you can't find the actual shocks you need locally try 4 wheel parts online or something like that to find ones that fit right
Old Apr 28, 2013 | 04:22 PM
Brandon Anderson's Avatar
Brandon Anderson
You can, but I wouldn't recommend it. The shocks on the 4x2 are what limits the downward travel of the suspension. Removing the shock allows the LCA to drop down basically an infinite amount.
