A/C issue
Old May 11, 2013 | 11:29 PM
rm4709's Avatar
rm4709
Default A/C issue
We have an 05 2500 diesel with a dead a/c. The 10 amp fuse pops when the unit is switched on. Previously I found a bad connection at the clutch plug, once that was addressed the unit worked flawlessly all summer. Now it is acting up again.
Today I had it checked by an independent shop, he figures the clutch is pooched. Can it be replaced without the pump?
Old May 12, 2013 | 01:03 AM
cuda19791's Avatar
cuda19791
Hi yes the compressor clutch can be replaced without replacing the compressor. I would make sure there is not a short to ground on the wire going to the compressor before you have the clutch replaced.
Old May 12, 2013 | 12:51 PM
rm4709's Avatar
rm4709
I assume he checked that but will do it myself to be sure.
Old May 13, 2013 | 09:24 PM
BigSloth's Avatar
BigSloth
it can be replaced, yes, but in most applications it costs more than replacing the compressor itself due to the labor. Better to just replace the whole unit.
Old May 15, 2013 | 10:25 AM
hillbilli's Avatar
hillbilli
The A/C clutchs are notorious for burning up on the cummins. It can be replaced or bypassed.
