Just bought a new Ram 1500 - LOT of questions!
Old May 14, 2013 | 08:53 AM
Kasper William Eriksen's Avatar
Default Just bought a new Ram 1500 - LOT of questions!
I just bought a ram 2004 ram 1500 4wd 5,7L Hemi, quad cab. it comes almost entirely stock, and I have a lot of modification wants for it.
first question, I ordered a 3'' torsion key front leveling kit, and a 2'' add a leaf for the rear, can I stack with suspension blocks too? or only bodylifts?
My last dodge came with a stock 4x4 locker, this newer dodge doesnt have one, and I need it, but i dont know where to look for one or what is the better locker.
I bought some 35'' tires for it, but im not sure wether the trucks gearing will pull the tires without messing up?
I really appreciate y'alls help thanks!
Old May 14, 2013 | 10:38 AM
04HemiGreg's Avatar
04HemiGreg
What is your stock gearing? You planning to tow anything heavy with the truck?
Are you expecting the truck to be level with 2" added in the rear? I haven't cranked mine that much and I do have aftermarket keys, but I'm not sure you'll get enough crank in the front to compensate for the factory rake + 2" in the back. I attempted to do the same thing on my Chevy and came up short. By the time I got close to level, the front end was like a buckboard and was undriveable.
Old May 15, 2013 | 05:20 AM
I'll be towing boats, trailers with hunrting gear and ATV's, From what I can find out the truck has stock 3,55 gears, but I am not sure.
I was hoping having the 3'' key in the front, and the 2'' in the back, it would either be level or riding with the front a little bit higher, i like it that way, but I was hoping that I would be able to increase travel more that those 3 and 2 '' without having to buy one of the really expensive lift kits right away.
Old May 15, 2013 | 09:48 AM
04HemiGreg's Avatar
04HemiGreg
I don't think you'll get there with the 2" in the back. You'll likely get to full crank before you get the stance you want. I bought a similar kit for my chevy and that's what happened - now, even with the front bars cranked, when I added the 2" in the back, I am pretty much right back to close to factory rake.
However, the reason I tried it is because the Chevy didn't come with the clearance that my RAM did and I had to raise it up to even run 285's. I'll let others comment that may have more specifics but I don't think you'll like it with 35's and 3.55 gears, especially towing stuff.
For reference, my sig pic is my RAM with no lift in the back, cranked to level in the front, and I have 34" tires. As you can see, there is still some room left. There is also some crank left in the front so if I wanted, I could have the front higher if I wanted it - that look just isn't for me - I like level.
Old May 15, 2013 | 01:00 PM
08HEMI1500's Avatar
08HEMI1500
3" in the front and 2 in the back will still give you a rake because the truck is naturally 2" higher in the rear then the front so you'll still have a 1" rake. Also, the safest height I've ever seen someone crank the t bars is 2", if you can even do 3" I wouldn't because you'll start messing with you CV angles too much. For lockers you are very limited for our trucks but if you have the money go for the locker and then regear while you're in the diffs. Since you tow i would recommend 4.56s, especially if you want 35s because 35 with 3.55 gearing will be terrible when you tow
Old May 16, 2013 | 03:55 AM
ok I see! so is there any alternative to lifting it in the front? like can I find some new shocks, springs and control arms that will give me a higher lift in the front to compensate for the add a leaf and stock lift in the rear?
I will go ahead and in install the locker with higer gear ratio! do y'all know where I can purchasse the parts?
Old May 16, 2013 | 08:58 AM
04HemiGreg's Avatar
04HemiGreg
Lots of people here like to buy parts from RockAuto. Not sure if you can get what you are looking for. I have bought things from them like gaskets and hoses for general maintenance. I don't think there is really any correct way to lift the front end more without a proper lift kit. Big jump in price, I know. That was the dilemma I was facing with my Chevy as well. Either spend a couple hundred dollars on shocks and keys and blocks to raise it up but not level it, or spend over a grand to lift the whole suspension. To make it worse for me, I have a 1500HD and that is more rare and so aftermarket lifts are harder to find. The only decent lift kit I could find for it was 6" and I didn't want anywhere near that. Companies used to make a 4" but discontinued it due to the rarity of the model and the lack of demand.
Old May 16, 2013 | 11:24 AM
08HEMI1500's Avatar
08HEMI1500
You could just not do the add a leaf and just stick with the blocks. I've read on here from members that add a leaf's aren't very good and make the ride really rough
Old May 17, 2013 | 12:26 PM
I found these 2'' ready lift T6 front billet leveling kit, can they be used with a torsion key possibly?
wow I actually thought that the add a leafs would creat a more comfortable ride!
Old May 17, 2013 | 12:43 PM
08HEMI1500's Avatar
08HEMI1500
Well you have to think. Add a leaf's would essentially make your back end like a 3/4 ton which has a harsher ride then a 1500 to begin with because of the extra leaf or two in its pack compared to the 1500s pack.
