Wipers acting funny
When I have my wipers on an intermittent setting they will sometimes wipe more than once. Is this the fix or is it something else?
https://dodgeforum.com/forum/3rd-gen...r-diy-fix.html
could fix it, could be multifunction switch or also bad wiper motor, just depends. One of those things will fix it. The diy is basically free, so its worth a shot, fixed mine obviously, that's why i posted it.
So I haven't messed with it yet, but have a new symptom. The interminet fuction quit working completely the other day, low and high still worked fine. Started working again after a couple minutes. Does that narrow it down any?
My '06 was doing the same thing. Like others said the Multifuncion switch should be covered under an extended warranty. (I recieved notification in the mail and actually had to show the paper to have it replaced).
Something that I noticed with mine was when it was acting up if I wiggled the multifunction switch around it would start to work. Almost like there was a short in the switch.
I didn't need the extended warranty notice when I went in. Just call your dealer and ask if your covered. If they say you need the letter I can send it to you. If you aren't the original owner they wouldn't know to send you a notice.
Trending Topics
I dont think that'll work. Yo got a letter because you were in the Dealer system and is why you didnt need it when you got it fixed. If he didnt get a letter, then he isn't.
Optional extended warranty work by dealer choice only includes original purchasers that owned prior to the factory warranty running out.
Any Mandatory Recalls mandated by Fed Gov't(NHTA), ALL current owners would get something in the mail even if the cehicle went through 45owners.
I'm not sure it's the switch, when they weren't working I monkey'd with the switch quite a a bit and it didn't seem to change anything. I wound up leaving it in the highest interment setting and flipping it to low and back when the window needed wiping. When they started working again I wasn't even touching the switch.
I've replaced my switch 3 times and rebuilt it before that. Taking it apart and cleaning it worked for a year. Nothing to loose it was broke. The new one worked for almost a year. I just wish they would go down when I turned them off. I've heard post say it could be the computer (pcm) I replaced mine with a used on when they head lights went out. Fixed the head light issue but not the wipers. Next would be the wiper motor I guess.
