Map of EVAP System?
Does anyone have this handy? The one that was in this thread is no longer available.
https://dodgeforum.com/forum/3rd-gen...m-diagram.html
Thanks!
Trey
Thanks!
Trey
getting an evap code?
google can come up with the diagram. That's how I found mine.
Just go under your truck. to the gas tank, and start at the charcoal filter. the big line without a connector is just the breather to the cap. take it off and make sure theres no build up of dust.
Then work on the other connention on the charcoal filter. take line off blow into it see what happens.
Thanks guys, The link didn't work for me at work but it does at home.
I have been getting a EVAP code almost right after I replaced all my Spark Plugs. Bought a new gas cap and put hose clamps on all the EVAP hoses. Still getting the P0442.
Trey
Trey
the top of the tank is the last resort, start with the lines at the charcoal filter. Check EVAP solenoid attached to charcoal filter, And go from there. Then theres the purge valve in the engine bay. To your right. You can trace back from the TB. to the valve.
