SRT-10 Push button
Old Sep 28, 2005 | 08:40 PM
FrankMcKeever's Avatar
FrankMcKeever
Default RE: SRT-10 Push button
NICE. Thanks for all of your help and info. Much appreciated.
Hopefully I can tackle this sometime next week
Old Sep 28, 2005 | 10:10 PM
RedRam225's Avatar
RedRam225
Good luck, and please let us know how it went (including pics!)
Old Sep 29, 2005 | 07:12 PM
hemiyellow's Avatar
hemiyellow
DC Insider
how clear were the instructions that came with the push button? i am also thinking about doing this and was just curious. i think it'd be sweet to have. and then all u had to do was hook the button to power, ground, and wire it to the ignition, right?
Old Sep 29, 2005 | 08:54 PM
spinfreak's Avatar
spinfreak
This is probably a stupid question, but will the switch work with a regular 1500 w/ the Hemi?
Old Sep 30, 2005 | 10:55 AM
DaHipaKea1313's Avatar
DaHipaKea1313
Ok I'm going to ask the question, I realize that you need to hook the wires into the ignition system, but do you need to turn thr key to the power on position or what?? I want to do this to to my Ram 1500.. There is a forum support buisiness that sells them too, there are 3 different colors. Check out the attachments.
http://www.lildevilmotorsports.com/
H-out
Old Sep 30, 2005 | 05:41 PM
RedRam225's Avatar
RedRam225
Hemi Yellow, the instructions are great. You hook pin number 2 to the yellow wire under the dash that goes to the starter, you hook pin number 1 to the hot wire from the cigaretter lighter, and that's all. it's very easy.
Spin Freak, yes it works fine on ALL vehicles. Art at Hensons' says he gets lots of orders for the thing, people puting them in everything.
DaHipaKea, I considered the aftermarket ones you've linked. SOme are lighted, and I think they would look very nice at night, in the end, I wanted Mopar origonal, but there is clearly no sin in going aftermarket; many light up, and I think those would look cool at night.
There is a seller on Ebay that says you need a relay for the switch to work, they are not correct. Art said that the Ram has a relay built into the starter, none is needed with the button. Good luck all.
And, yes, it is actually a silly mod, you do have to put the key in, and turn it to the "on" position then you push the button to start. BUT it is a sweet mod if you have a loud exhaust, cause you get the "push to rumble" experience.
Old Oct 2, 2005 | 11:43 AM
aviator's Avatar
aviator
I put one in my truck and used an electrical washer (from home depot). I had to open the center a bit to get the button to fit. I painted it black and it looks pretty good. Also, when I hooked it up I cut the yellow wire and connected it to the start button. That way I have to use the button to start it. I love taking it into the dealer and watching the guy try to figure out why it won't start when he turns the key.
Old Sep 18, 2006 | 04:12 AM
SMDR's Avatar
SMDR
Just want to thank everyone on this post, just by reading all the info, I be able to instal my push button start on my 04 Dodge ram today.
Many thanks again!
