Fuel Pump or Starter???
Old Jun 25, 2013 | 02:23 PM
hitmand850's Avatar
hitmand850
Default Fuel Pump or Starter???
NEW PROBLEM. When I try to crank my truck it turns over and tries to crank but just won't. But if I turn my key to the on position and wait for the 5 beeps then turn it off and try to crank it it works. Go figure I've doing that for the past few weeks. i cleaned the throttle body , but no results. Is it my starter going out or is it just not getting the fuel from the fuel pump.
Vitals:*04 ram 1500, 5.7L Hemi, 152k miles
Old Jun 25, 2013 | 02:54 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
A fuel pump would have no effect on the engine turning over. If it's spinning freely when you turn the key, but not firing up, it's the fuel pump. If the engine is not spinning freely then you have a starter/battery issue.
Now, you said that you have to basically let the key sit twice before you start it, THAT can be indicative of a fuel pump going south.
Old Jun 25, 2013 | 03:46 PM
BigSloth's Avatar
BigSloth
That usually means the check valve in the fuel pump is allowing fuel pressure to bleed back into the tank. But there could be several other reasons but that is the most common.
Old Jun 25, 2013 | 04:52 PM
Gone Fishin's Avatar
Gone Fishin
5 beeps----is a dtc code being set
Old Jun 25, 2013 | 06:13 PM
MikeHTally's Avatar
MikeHTally
If it turns over, it ain't the starter. What you're describing sounds like a fuel pump failure - the fuel rail pressure is not staying up. Try turning the key on and counting to five, then turn to "Start". I suspect it'll fire right up.
Old Jul 2, 2013 | 04:18 PM
hitmand850's Avatar
hitmand850
hey Mike that worked for a little while but now it just coughs like its sick and cranks whenever its ready. Stubborn lil mule. How hard is it to drop the tank and change that fuel pump?Its no point in putting my CAI on if it wont crank when needed
Old Jul 2, 2013 | 05:51 PM
MikeHTally's Avatar
MikeHTally
Some folks drop the tank, others loosen the bed and move it back. That seems a better way. Do you often "run it down to fumes"?
