v6 power
Old Jun 30, 2013 | 05:01 PM
03ram3.7mag's Avatar
03ram3.7mag
Default v6 power
I have a 03 ram with 3.7 mag bough the truck hoping v6 would get better gas mileage turns out its not much better then bigger engines but to late now just looking for some feed back now that I have the truck I want to get the most power out of the v6 as possible I know I start most likely with cold air intake but what do yall say I do from there
Old Jun 30, 2013 | 05:03 PM
03ram3.7mag
not trying to dump thousand under the hood
Old Jun 30, 2013 | 06:12 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
Tuner (programmer) would be the best bang for the buck, if they make one for the 3.7 Ram. You'd have to research to see if there are any.
Then exhaust, then maybe a CAI. Tuner would run you a few hundred, exhaust would be variable depending on exactly what you want done, and CAI would run a few hundred. Cheap and performance don't go hand in hand ever, especially with an underpowered truck (no offense intended).
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Jun 30, 2013 | 06:29 PM
HemiLonestar's Avatar
HemiLonestar
The Hypertech doesn't apply to 03's according to their website, but there is abetter than even chance Hemifever can custom tune yours. Just need to send in your PCM p/n to see if its compatible with SCT. Sean has done quite a few 3.7's in and out of Rams (like my wife's Liberty). Higher numerical (lower) gears would definitely help in the get it moving department, as would an aftermarket torque converter. Beyond these you're looking at head work, custom ground cams and bored TB.
Old Jun 30, 2013 | 07:13 PM
MikeHTally's Avatar
MikeHTally
Well, you should have done your homework first. Putting that old V6 into a full-size pickup cannot have been a good idea. Just as the Hemi actually provides equal mileage as the 4.7, it also willl equal or better the V6. Nothing you can do will make much improvement. It's under-powered, period.
Old Jun 30, 2013 | 07:36 PM
03ram3.7mag
meant thousands above 1500 2000 prolly the most id want to put into it
Old Jun 30, 2013 | 10:28 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Go with a Spectre drop-in filter, and a tuner.
Don't bother with exhaust as it's just sound.
Then save up to get a Hemi.
