04 dodge ram 1500 wiring
Old Jul 6, 2013 | 04:46 PM
Frank Lucero's Avatar
Frank Lucero
Default 04 dodge ram 1500 wiring
Ok guys I need help with the wiring on my truck! I'm having trouble with my lights dimming loss of power I can't hook up nothing without my lights flashing does anybody have any ideas?? I've changed the alternator to a high output and I have hid's on my truck and leds on the back for all three! Now interior I have an aftermarket radio but I've gone over it plenty of times and everything is wired right so I'm thinking of just having the truck completely rewired do they have kits to do this and if so where?
Old Jul 6, 2013 | 07:51 PM
generaljr's Avatar
generaljr
try disconnecting the wiring harness from the stereo, and see if it takes away your issues
Old Jul 6, 2013 | 08:01 PM
kejobe's Avatar
kejobe
Could also ask the 3rd Gen guys.
Old Jul 7, 2013 | 05:04 PM
rought's Avatar
rought
could be the fuze box check this thread ;; https://dodgeforum.com/forum/3rd-gen...ml#post2205521
Old Jul 7, 2013 | 10:01 PM
Frank Lucero
Ok well today I disconnected the radio and all wiring and I still have the same problem! the lights dim when I roll down my windows turn the radio up loud anything I add to this truck drains power! I feel I'm going to have to change the fuse box!
Old Jul 7, 2013 | 10:21 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Old Jul 7, 2013 | 11:37 PM
rought's Avatar
rought
Before you buy a new fuse box take apart your old one and see if the board is corroded.
You have to drill out the tabs in the middle of the box, but you can put it back together and use it, if its ok. They are not cheap..
Old Jul 8, 2013 | 01:43 PM
Frank Lucero
Weedahoe I've already done the big three upgrade I've ran 0 ga on all three but nothing it still does the same so I think I'm going to have to look into the fuse box as I have learned these are not water tight and if you go through I good size puddle you could damage it so that's my next conquer!
Old Jul 14, 2013 | 07:17 PM
Frank Lucero
rought are there three pins i need to drill to seperate the fuse box
Old Jul 15, 2013 | 10:35 PM
Frank Lucero
Ok I pulled apart the fuse box and no damage as far as I can see now I'm going to check the PCM!
