2002 4.7L White sweet smoke out the exhaust
Hello,
I have a 2002 Ram 1500 4.7L and started getting a white, sweet smelling smoke out the exhaust recently. I read over the similar issues on the forum but none seemed to have all the answers for my issue after I have run some tests. For some background I have 125k on it. It does not and has not over heated at all. For some background I have replaced the heater core, water pump, rad and rad cap all within the past 3 years from wear and tear, all were original.
To narrow down the smoke issue I started by turning over the truck with the rad cap off, and had no rush of coolant out the top. Then I ran a compression test and 5 of 8 cylinders read a 120, the other 3 varied from 90 to 110. I added some oil to those cylinders and they all came up to 120. I ran a coolant compression test too and had no external leaks. The oil looks fine and does not have a milky color. I was told by the auto store that the intake manifold on the 4.7L does not have coolant running through it. Is he right?
I feel like I have ran every test to narrow down the head gasket and none of them have turned up anything. Can anyone point me in the direction of another test or have seen anything like this happen?
Thank for the help!
Thank for the help!
Well that much isn't much but, It's still not right. As you probably know, you should be at your fill mark all the time and not need to top anything up.
I don't know if this amount would be why your seeing that white smoke and smelling the sweet smell.
Sweet smell could = burned coolant.
There is a test you can buy, where you take a sample of coolant from your radiator and the test checks if there's emission gasses in the coolant.
That will tell you 100% if there's a head gasket problem.
You can get this kit from major auto stores.
Al.
Al.
Trending Topics
