How can I tell if my timing chain is bad
Old Aug 4, 2013 | 12:59 PM
stervwakefield's Avatar
stervwakefield
Default How can I tell if my timing chain is bad
I've got a 03 ram 1500 5.7 hemi.
When i try to start my truck, the engine will turn over but there is some clanking and it immediately dies. is there a way I can tell if it's the timing chain without tearing everything apart?
Old Aug 4, 2013 | 02:23 PM
MikeHTally's Avatar
MikeHTally
Timing chains usually have a considerable life span. How many miles?
Old Aug 4, 2013 | 03:22 PM
stervwakefield
I just past 126000 miles
Old Aug 4, 2013 | 05:34 PM
Gone Fishin's Avatar
Gone Fishin
I'm at 180K on the original--no problems
Old Aug 4, 2013 | 06:50 PM
p38251's Avatar
p38251
I would say you need to do some further investigation. The newer vehicles very rare to have issue with timing chains. Maybe rod or bearing issue.
Old Aug 4, 2013 | 07:45 PM
MikeHTally's Avatar
MikeHTally
Unless it's been abused, that chain has another 80K at least. Maybe it broke a valve spring and swallowed a valve?
Old Aug 4, 2013 | 07:55 PM
stervwakefield
I'm gonna get into it tomorrow to try and diagnose it better. But one of the things that I don't understand is I had gone on a drive for about two and a half hours with no signs of any problem, then I had the engine off for about 10 minutes and when I tried starting it back up it wouldn't go.
Old Aug 4, 2013 | 08:01 PM
stervwakefield
I wouldn't say it's been abused but it does have some hard miles on it with regular maintenance, and I did have the valves redone at about 75000 miles.
Old Aug 5, 2013 | 09:17 PM
jmjc1c's Avatar
jmjc1c
I am having the same problem on my 06 Ram 5.7L V8 hemi 4x4 186,000 miles. I ran the truck one morning, turned the truck off and it would not turn over. I have replaced the spark plugs and have the ignition coils on order. I have 3 codes that all lead to bad or misfiring ignition coils/spark plugs. Ill keep yall updated. Good luck
Old Aug 6, 2013 | 06:20 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like the dreaded 03 broken valve springs. Pull the valve covers and have a look around.
