air conditioner not cooling at a stop
Old Aug 10, 2013 | 06:59 PM
ellismj75067's Avatar
ellismj75067
Default air conditioner not cooling at a stop
My 2006 Ram 1500 Hemi has been having problems cooling at a stop or in town traffic. It cools great on the highway. I replaced the fan clutch today expecting resolution, but was very disappointed when I drove it to find it still wasn't cooling properly. Again, it works great on the highway.
Anyone else had this problem? Is it possible that I got a defective fan clutch? Can anything else cause this problem?
Old Aug 10, 2013 | 08:36 PM
djibara's Avatar
djibara
Is it your airconditioning or radiator your talking about?
Old Aug 11, 2013 | 12:50 AM
Rkymtnh's Avatar
Rkymtnh
Take it to a garage and have your A/C re-charged.
Old Aug 11, 2013 | 06:28 AM
Gone Fishin's Avatar
Gone Fishin
Before you do that, check to make sure the condenser fan is working. Its the electric fan on the smaller radiator looking coil. The fan runs all the time the a/c is turned on.
Old Aug 11, 2013 | 06:59 AM
cnshough's Avatar
cnshough
Most likely, you need one of these...
http://www.rockauto.com/catalog/more...604&cc=1432338
It's an easy fix for someone mechanically inclined. I'm not, but it only took me a couple hours on a saturday to change it out.
Watch this:
And part 2:
Difference is, when you get it out, you're just going to remove the motor from the fan and replace just the motor, then put it all back together.
Old Aug 11, 2013 | 11:44 AM
ellismj75067
Air conditioner
Old Aug 11, 2013 | 03:08 PM
HemiLonestar's Avatar
HemiLonestar
Yup, condenser fan.
Old Aug 11, 2013 | 11:02 PM
HammerZ71's Avatar
HammerZ71
Check the condenser fan, but could also be a vacuum leak. When you are moving and rpms are up the system can overcome a minor leak, but when standing still it can't overcome it. BOTH are fairly common...
Old Aug 12, 2013 | 12:40 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Another +1 to the condenser fan.
Old Aug 12, 2013 | 09:47 AM
Izero's Avatar
Izero
Condenser fan is the first place to check, next thing to do if the fan is working is go and get some simple green at walmart or any grocery store, soak your condenser with it, let it sit for about 10-15 min and just rinse it out with a hose.
Spray every inch of it from both sides starting with the inside (engine bay side)... that will blow all the road grit and other crap outa there.
