Asp underdrive pulley
Old Aug 13, 2013 | 12:26 AM
jaebersold's Avatar
jaebersold
Default Asp underdrive pulley
Hey guys..I know this has been talked about but,I want to hear from people that has this pulley..Im not worried about Air-rams super damper..Im getting the Asp pulley if anything...Is it worth it or not?I will be doing a new E-Fan with the pulley..I want to do it all at once..I just want some feed back on if the 285 is worth it or not and If they have felt a difference..Thanks
Old Aug 13, 2013 | 02:43 AM
KasperR34's Avatar
KasperR34
No, do not do it.
Old Aug 13, 2013 | 03:09 AM
jaebersold's Avatar
jaebersold
Thanks..(Kasper)..Truck looks awesome bro
Old Aug 13, 2013 | 08:00 AM
TRO14's Avatar
TRO14
I run a 20% underdrive pulley from summit. It is a very nice piece and makes a noticeable difference from a stock size pulley. It is a fairly easy mod that gives nice gains and installs very quickly and easily.
Old Aug 13, 2013 | 09:29 AM
jaebersold's Avatar
jaebersold
Im running a 4.7..So sorry I didn't state that...I messed up..So I have 1 for yes and 1 for no..
Old Aug 13, 2013 | 06:17 PM
KasperR34's Avatar
KasperR34
Thank you sir
Just remember, if you do this:
Your alternator puts out 20% less current. If you have a 130 amp, now you have a 104 amp
Your AC condenser is running 20% less
Your Power Steering pump is 20% less
Water Pump is 20% less, and the cooling system is very important on a 4.7 lol
Does that small gain seem worth this?
Old Aug 13, 2013 | 07:05 PM
TRO14's Avatar
TRO14
Don't let him scare you off. Theoretically those things could all be problems but reality is that I and many other guys run them with none of those problems.
Old Aug 13, 2013 | 07:06 PM
redram2007's Avatar
redram2007
I just ordered the ATI only bc i want something that is well known. I have read a lot of bad reviews on the ASP so i went with the ATI. Also the ATI is actually a smaller damper with a 25% UD pulley where the ASP is a regular sized damper with an UD pulley. Yes you will lose a percentage of your other accessories but they also make an OD pulley for the alt. Although if i see any change in voltage im going to add the Durango 160 amp alt. IMO
Old Aug 13, 2013 | 07:17 PM
KasperR34's Avatar
KasperR34
Do this to add more power
Old Aug 13, 2013 | 08:32 PM
redram2007's Avatar
redram2007
That's worth at least 100 RW HP.
