AC problems! Need Help!
Old Aug 13, 2013 | 10:29 PM
redrumrevolution1's Avatar
redrumrevolution1
Default AC problems! Need Help!
Im having major problems with my AC unit in my 2004 ram 1500(5.7). My AC don't blow cold at all. It just started bout a week ago. Before than the AC only blew cold when the truck was moving because the condenser motor went out. I was seating at a light bout a week ago and I heard a squealing noise from under the hood. It stop when I took off and ever since than the ac didn't blow cold any more. I believe it came from the compressor because the black ring by the compressor pulley is shredded a bit. Im on a tight budget. First thing I going to do is change to motor out of the condenser fan. What would be the next step? Should I change out the compressor? If so should I get a new one, take mines to get rebuilt, or is there some possible way I can fix the compressor myself?
Old Aug 13, 2013 | 10:34 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Sounds like the compressor may have locked up. Does the center turn when you have the A/C switched on?
