Instrument Cluster or Wire Issue?
Old Aug 16, 2013 | 06:01 PM
JoshImlay's Avatar
JoshImlay
Default Instrument Cluster or Wire Issue?
I have a 2002 Dodge Ram pickup just recently after it sat for a couple weeks when I went to start it up it started fine but I had no gauges turn signals high beams almost everything electrrical was down minus radio. After doing some research I found most problem to be the instrument cluster. Bought one and just recieved it today as I went to replsce it first off the 3 wire connecters were flipped. Where mine white was on lefg and 2 black were on right this one wad the opposite but was stillbout of a 2002. To make matters worse the new cluster went in and my truvk then wouldnt start. I put the old onr back on and startrd tinkering the white wire on the back i then had lights and everything but once i moved agsin they shut off. But at this point still wouldnt start once it had been installed. I dont trust dealerships anymore so I wanna get as much info as I can before I may end up having to take it. Any and all help would be greatly appreciated.
Old Aug 16, 2013 | 08:49 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Check your battery connections and fuses first
Old Aug 18, 2013 | 06:50 PM
JoshImlay's Avatar
JoshImlay
But with fuses isnt that to many things to be pff for it to be something as simple as a fuse. I pulled ever fuse that sounded like It could have had something to do with it but none of them had tripped.
Old Aug 18, 2013 | 07:04 PM
lxman1's Avatar
lxman1
Site Moderator
Could be a bad fuse box under the hood. Check the bottom side for moisture/corrosion.
Old Aug 19, 2013 | 09:03 PM
JoshImlay's Avatar
JoshImlay
Heard back from the person I bought cluster from. They now said that they sent me the wrong cluster. Now my question is, if a different uear cluster is installed then the model year truck could thay edfext why my truck wont start now. Now mind you the only difference like I said is in the back the wire adapters, normally white connector is on left 2 black ones are on right. Thi is is opposite, any info os very helpfuul.
