radio wiring diagram
Old Aug 29, 2013 | 03:32 PM
magnethead's Avatar
magnethead
Default radio wiring diagram
for a side project, cut it out of an 07 ram.
Radio is a diamler P05064173AK single CD double DIN.
Has 2 connectors.
C1: green/yellow, green/orange, green/green
C2:
ground?:
black
black/green
green/yellow and green/blue (braided)
green/tan and green/light green (braided)
tan/yellow and tan/blue (braided)
tan/green and tan/light green (braided)
white/white and white/orange (braided)
power?:
gray/pink and gray/pink (braided)
I just need the 2 power wires, ground, and the 4 speaker wires.
Thanks.
Old Aug 29, 2013 | 03:43 PM
magnethead's Avatar
magnethead
Note to self: google. But still not sure what the white/white and white/orange braid are. CAN bus maybe?
+12V: Grey / Red
Radio Ground: Black and Black/Light Green
Radio Ignition (CAN data bus) ** See Note
LF Speaker +: Dark Green/Yellow
LF Speaker -: Dark Green/Light Blue
RF Speaker +: Gray/yellow
RF Speaker -: Gray/Light Blue
LR Speaker +: Gray/Light Green
LR Speaker -: Gray/Dark Green
RR Speaker +: Dark Green/Light Green
RR Speaker -: Dark Green/Gray
Switch is the pink/white wire in the ignition harness....your cigarette lighter might be switching also...you will have to test to see
Old Aug 29, 2013 | 03:50 PM
Izero's Avatar
Izero
+12V: Grey / Red
I think Orange/white and white/white might be the 7th speaker on an infinity, or it might be illumination for the dimmer control which would only be the Orange/White, which means the White/White might be the CAN-BUS connection.
It's been awhile so I can't 100% remember them all.
Old Aug 29, 2013 | 04:03 PM
magnethead's Avatar
magnethead
ok, got power to it and the clock comes up, but cant find ignition positive. claims to use the CAN bus positive wire (white/orange), but no dice.
Old Aug 29, 2013 | 04:07 PM
magnethead's Avatar
magnethead
ok, really? Reading up, the CAN bus is required to be present for the radio to turn on. What a crock of BS.
Old Aug 29, 2013 | 04:15 PM
magnethead's Avatar
magnethead
figured it out
http://www.daytonaturbo.com/images/22pinconnector.pdf
http://daytonaturbo.com/tech-zone/12...-radio-upgrade
My radio connector doesn't have pin 2 connected. Shoved a wire in there, hey look, a radio!
Old Aug 29, 2013 | 08:02 PM
Brandon Anderson's Avatar
Brandon Anderson
I didn't know you could install a CANbus radio into a non CANbus vehicle. That's interesting to know.
Old Aug 29, 2013 | 10:10 PM
magnethead's Avatar
magnethead
apparently it looks for either a signal on the CAN bus, OR a signal on pin 2. However, the factory harness omits pin 2, and it has to be added manually.
also, both power and both grounds are internally connected. So only 1 of each is actually necessary.
