Water Pump,Thermostat or just ten.sensor.
Old Sep 13, 2013 | 03:38 PM
hitmand850's Avatar
hitmand850
Unhappy Water Pump,Thermostat or just ten.sensor.
I have a 04 1500 w/ 158,000 miles. Lately my temp rises and falls constantly. Of course it rises more at idle. But it goes up to the max and then cools down as I continue driving. I dont wanna wait until too late to find out whats wrong. I have also noticed Im getting white smoke from the exhaust because there is apparently a coolant leak somewhere. What should I start with in order to fix these issues? I'm already gonna be under there tomorrow putting on a starter. So I wanna spend all day on it, to have it ready for the work week.
Old Sep 15, 2013 | 05:59 PM
jasonw's Avatar
jasonw
Site Moderator
Moving you to the correct spot.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Sep 15, 2013 | 07:06 PM
abarmby's Avatar
abarmby
Temp gauge at max..... White smoke from exhaust..... Hmmmmm Let me think.........= head gasket.
Al.
Old Sep 15, 2013 | 09:21 PM
rtmtrrdr's Avatar
rtmtrrdr
its probably started with the t-stat sticking and then the head gasket went. I'd try doing the t-stat and see what happens
Old Sep 16, 2013 | 11:55 AM
hitmand850's Avatar
hitmand850
I changed the thermostat and it ran fine that day ,but the very next day the temp. started to rise again.
Old Sep 16, 2013 | 05:38 PM
gordie580's Avatar
gordie580
I had the same problem with temp. Not the white smoke, but mine was the fan clutch quit working. So the fan would free spin and not engage so it would run hotter while idle or driving slow, and would be normal temp while driving on the highways.
Old Sep 16, 2013 | 05:56 PM
MikeHTally's Avatar
MikeHTally
Al.
Yeppir. It's been run too hot for too long.
Old Sep 17, 2013 | 06:37 AM
rought's Avatar
rought
put a 180 degree thermostat in it too makes the truck run a lot cooler.
Jet makes a good one.
