No turnsignals whatsoever!! HELP!!
Old Sep 14, 2013 | 07:04 PM
66three83's Avatar
66three83
Default No turnsignals whatsoever!! HELP!!
2006 1500 Mega Cab Hemi.
Went out to dinner tonight, and noticed my right signal indicator on the cluster was blinking quickly. No problem, just a bad bulb right? Pulled over and checked the bulbs, no front right, no rear right. Thinking uh oh, what are the chances both bulbs went out at the same time.
Since I had a spare rear bulb in the glove box, I changed it right there. Still nothing on that side, front or rear. Oh well, I'll address it when we get home.
Left the restaurant, and now, no left signals either!! Just a rapidly flashing indicator on the cluster. I honestly don't know where to start..... Any Ideas????
BTW NO HAZARDS EITHER!!!!
Old Sep 15, 2013 | 04:43 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Did you check for a blown fuse
Old Sep 15, 2013 | 04:46 PM
Chase Lejeune's Avatar
Chase Lejeune
blown fuse or bad relay would be my best guess
Old Sep 15, 2013 | 11:06 PM
66three83's Avatar
66three83
On an 06 there are fuses??? Or relays???? 06 uses tipm. The only fuse that comes close is the parking lights right and left. I was hoping for something more useful. Thanks anyway.
Old Sep 15, 2013 | 11:14 PM
66three83's Avatar
66three83
Okay, I guess I left myself open by saying I don't know where to begin. I do know, and I checked everything. After exhaustive searches on the subject, I believe it's my tipm unit. I am hoping it can be flashed, reset, or whatever. Replacement is probably going to be required I fear. I was just hoping someone else had the miracle cream I could rub on my truck!!! I'll let you know what I find out tomorrow after I call a few dealers, and hopefully find one that will try and flash my tipm. From what I've read, most just want to replace.
Old Sep 16, 2013 | 11:09 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
No truck or car today is without fuses
Old Sep 16, 2013 | 11:48 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
It wouldnt hurt to take a meter and set it to continuity and test each fuse.
From page 686 of 9267 of the 2006 Srv Man
FUSE LOCATIONS & TYPES
SPECIFICATIONS
FUSE PANELS
CAUTION: When replacing a blown fuse, it is important to use only a fuse having the correct amperage rating. The use of a fuse with a rating other than indicated may result in a dangerous electrical system overload. If a properly rated fuse continues to blow, it suggests a problem in the circuit that must be corrected.
NOTE: If you are leaving your vehicle dormant for longer than 21 days you may want to take steps to protect your battery. You may do this by disconnecting the battery or by disconnecting the two ignition-off draw (I.O.D.) fuses located in the Auxiliary Power Distribution Center (PDC) located in the engine compartment. The I.O.D. cavities include a snap-in retainer that allows the fuse to be disconnected, without removing it from the fuse block. Pressing the I.O.D. fuse back into the cavity reconnects it.
Underhood Fuses (Integrated Power Module)
Cavity Fuse/Color Description
1 20 Amp
Yellow
Power Outlet Console
2 20 Amp
Yellow
CCN Door Locks
3 20 Amp
Yellow
Spare
4 20 Amp
Yellow
Spare
5 20 Amp
Yellow
Sunroof
6 10 Amp
Red
Rt T-Tow Stop/Turn Rly
7 15 Amp
Lt. Blue
Park Lamps Rly
8 10 Amp
Red
Lt Park Lamps
9 30 Amp
Pink
T-Tow Park Lamps
10 5 Amp
Orange
Rt Park Lamps
11 10 Amp
Red
Rad Fan Hi Rly
12 30 Amp
Pink
FCM Batt #4
13 25 Amp
Clear
FCM Batt #2
14 15 Amp
Lt. Blue
Adjustable Pedal
15 20 Amp
Yellow
Ft Fog Lamps
16 15 Amp
Lt. Blue
Horn
17 15 Amp
Lt. Blue
Spare
18 40 Amp
Green
FCM Batt #1
19 30 Amp
Pink
Lt T-Tow Stop/Turn
20 10 Amp
Red
FCM Batt #3
21 10 Amp
Red
Rt T-Tow Stop/Turn
22 2 Amp FDCM Mod
23 10 Amp
Red
Rad Fan
24 20 Amp
Yellow
Rad Fan Lo Rly
25 10 Amp
Red
Ft Fog Lamps Rly
26 20 Amp
Yellow
Adjustable Pedal Rly
27 40 Amp
Green
IOD #1
28 10 Amp
Red
IOD #2 (Audio)
29 10 Amp
Red
ORC (Ign R/.S)
30 15 Amp
Lt. Blue
Spare
31 10 Amp
Red
Powertrain Control Module (PCM), Transfer case Brake Signal
32 10 Amp
Red
HVAC, Adjustable Pedal, Heated Seat Switch, Exhaust Brake
33 10 Amp
Red
Power Ignition run Mics.
34 10 Amp
Red
Spare
35 15 Amp
Lt. Blue
CCN Illimination
36 25 Amp
Clear
Audio Amp
37 15 Amp
Lt. Blue
Spare
38 20 Amp
Yellow
Power outlet IP
39 10 Amp
Red
Sunroof/Seatbelt
40 20 Amp
Yellow
Cigar Lighter
41 25 Amp
Clear
Spare
42 30 AmpPink
Diesel PCM
Old Sep 16, 2013 | 11:49 AM
stenerson's Avatar
stenerson
Multifunction switch? I had similar problems a couple years back and had to change it. Did it myself, not hard.
Old Sep 16, 2013 | 09:09 PM
66three83's Avatar
66three83
It was finally diagnosed today... my TIPM is shot. Dealer tried to reset/flash it, to no avail. I am getting a new one on Wednesday. I will post after that to update.
Old Sep 16, 2013 | 09:23 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Glad you were able to get a dealer to look at it so quickly. Thats very unusual. Also glad you were able to get them to diagnose it. What did they say a new TIPM was going to cost you?
