2wd daystar spacer help!
I have a 2005 ram 1500 hemi with stock 20" wheels and i was looking to level it so i ordered some daystar spacers. They I believe they are 1.5" spacers because they measure 2.5" on the outside and are 1.5" on the inside. they have been sitting on my dresser for some time now because i have read that i need longer shocks and all i can find on this world wide web are shocks for 4wd trucks. If some one could please post a link to the shocks i need would be great. My ride is already pretty stiff so I dont want to make it worse so would it be possible to get longer yet softer maybe adjustable shocks?
I believe the Pro Comp ES3000 and 9000s work as well as the Rancho RS5000s. You will only need shocks that are 2" longer then stock. I would check out autoanything, rock auto or moes performance. Moes' deals exclusively with Rams so he should be able to hook you up.
I have es9000 and they are for a 6 inch lift. Unless they come in different lengths?
alright guys so the install went smoothly. it looks great but i have two problems, one im assuming is the alignment but when i turn the wheel doesnt straighten back out i have to manually turn the wheel back straight and two is that when i go over bumps i hear a loud clank in the front but i cant seem to find what is hitting. it drives smoother than before and i parked it with one wheel up on the curb and nothing is close to even touching but its driving me crazy
Trending Topics
i think they were the 2.5" spacer because it ended up raising the front end almost 4" and leveled it out perfectly. I got an alignment and that fixed any steering problems i had but i believe the popping i experience is actually the ball joints. the truck has 105k miles and i am unsure if they are the ones from the factory or not but ill probably replace them when i add in longer spindles
