valve cover blows up
Old Sep 23, 2013 | 06:56 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Originally Posted by MikeHTally
No, they're aluminum (I'm in the process of taking mine off to change the valve springs )
Got it.
And I just realized this is a 4.7....I know the early ones have magnesium covers. What do the later ones have? Aluminum?
Old Sep 23, 2013 | 07:22 PM
MikeHTally's Avatar
MikeHTally
Looks like plastic to me. I'd think magnesium would've shattered. His looks like someone took a chain saw to it.
Old Sep 25, 2013 | 10:05 AM
Tazmonster's Avatar
Tazmonster
Doing a compression test today. Looks like detonation in cyl 1.
Replaced the PCV valve when I did the head gaskets last month.
I should know tonight if I blew the motor up
Old Sep 25, 2013 | 10:07 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Out of curiosity, what type and octane fuel are you using?
Old Jan 15, 2021 | 12:06 PM
Maranda Shoemaker's Avatar
Maranda Shoemaker
I recently experienced a very similar incident with the valve cover in my durango. I fill it up with non ethanol fuel. Would that be the cause? I had recently changed the rocker arms prior to this happening. I could post pics if needed. It still runs and drives but doesn't sound too good.
Old Jan 15, 2021 | 10:03 PM
Magnoom's Avatar
Magnoom
Veteran: Navy
Veteran: Coast Guard
Over seven years ago......
Old Feb 7, 2021 | 10:21 AM
k carter's Avatar
k carter
Default Mm 7 Dodge Dakota 4.7 blue off valve cover
Originally Posted by Tazmonster
So quick run down blew my head gasket had that fixed (117K).
Truck has been running fine, but I took the camper out this week end only a 30 min drive from home.
Heading there everything is good. coming home I see a check engine light come on. I'm driving up a long hill kinda steep. and check engine light comes on. Top the hill hook my code scanner to it and it shows a miss fire on 2.. I'm about halfway home and that's the worst hill so I puppy it home.
5 min from home I stop at a light a very small hill. when I pull away i get a loud BOOM a cloud of white smoke. Motor is still running I turn the corner quick and pull into a parking lot. Pop the hood and the valve cover is blown apart.
anyone have any insight, I'm thinking a back fire due to the misfire.
My buddy who does all my mechanic work (50 years as a mechanic) sees it and says he never saw a valve cover blow apart like that.
haven't gotten it apart yet to see if anything else is wrong but still only show a 302 code in the scanner.
2006 2006 Dodge ram 4.7
Last edited by k carter; Feb 7, 2021 at 10:22 AM. Reason: Didn't get to put the body intothen understand when it says title I would assume you would want to just put in what you want to stay but there w or area for me to explain that I had the same situation
