2005 Ram 1500 Making Noises when I Turn?
Old Oct 13, 2013 | 05:23 PM
bookwaters's Avatar
bookwaters
Default 2005 Ram 1500 Making Noises when I Turn?
I could use some advice. My truck is making noises off and on when I make turns and the noise lasts a very short distance after the turn. There aren't any problems when I brake or accelerate. It's kind of a pinging sound like something caught in a spoke and there is a bit of a grinding feel through the pedals. Only occurs immediately after a full left or right turn. Seems to have to warm up first to start occurring.
I took it to Meineke and they said there isn't anything wrong with the front end. They also said a boot was out of place and there was a little give on the wheel bearings but not enough to be worth replacing. Is this a transmission issue? I have a bit over 100000 miles on it now.
When should I worry about the noise?
Old Oct 13, 2013 | 07:44 PM
p38251's Avatar
p38251
Sounds like you may have a wheel bearing going bad
Old Oct 14, 2013 | 12:47 AM
Will_V2Lab's Avatar
Will_V2Lab
I second the wheel bearing idea.
Does it make noise when you turn a certain direction? Or just left or right?
Old Oct 14, 2013 | 01:33 PM
bookwaters's Avatar
bookwaters
Just makes noises when I turn left or right after it has been driven a mile or so. Though I think I heard the noise start up and then stop when I was driving straight.
Old Oct 14, 2013 | 11:26 PM
Will_V2Lab's Avatar
Will_V2Lab
Yep definitely sounds like a wheel bearing.
Old Oct 15, 2013 | 11:03 AM
DirtyDodge812's Avatar
DirtyDodge812
Wheel bearing noise is usually heard at all times and gets louder as speed increases. If its a 4wd truck it could be the cv shafts, or a combination of those and the intermediate shafts.
Old Oct 21, 2013 | 01:16 PM
bookwaters's Avatar
bookwaters
Default Verified
Took it to Midas and they verified that the wheel bearing is going out. Noise is also occuring more often. I know what I'm doing this weekend.
