leak out coolant overflow tube
Old Oct 16, 2013 | 11:48 PM
swamper's Avatar
swamper
Default leak out coolant overflow
im losing coolant out my overflow tube. i replaced the cap but im still getting a leak I cant seem to figure out what the problem is and the coolant is not over filled.
Old Oct 16, 2013 | 11:51 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Sounds like pressure is building up somewhere.
Old Oct 17, 2013 | 12:00 AM
master tech's Avatar
master tech
Site Moderator & Tech
Is the overflow bottle full? Because like dodge dude had said, you maybe building up pressure in the radiator and the coolant is over flowing into the bottle.
Old Oct 17, 2013 | 12:50 AM
swamper's Avatar
swamper
the overflow bottle is about a quarter down from the full line.even when its filled it leaks the truck has a new radiator.what should I check next?
Old Oct 17, 2013 | 10:28 AM
master tech
I would perform a cooling system pressure test.
Old Oct 17, 2013 | 10:37 PM
swamper's Avatar
swamper
did the pressure test today was normal now what should i check?
Old Oct 18, 2013 | 09:58 AM
66three83's Avatar
66three83
The nozzle that the rubber overflow tube connects to could have a crack where it meets the filler neck of the radiator. Or could just be a loose fit. Or the hose itself could have a hole. I would replace the hose next, and maybe put a small clamp on it.
DirtyDodge812's Avatar
DirtyDodge812
Blown headgasket or cracked head could cause the same problem. I would think it would show on a pressure test though...
