Steering shaft?
Old Oct 29, 2013 | 06:20 AM
ccgRAMrod's Avatar
ccgRAMrod
Default Steering shaft?
Found my problem, worn steering shaft. Anyone recommend a aftermarket better then OEM? Or is OEM the way to go?
Thanks
Old Oct 29, 2013 | 07:02 AM
ccgRAMrod's Avatar
ccgRAMrod
Also found that the geerbox can have slop in it and be adjusted. Anyone have luck doing this?
Old Oct 29, 2013 | 05:21 PM
ccgRAMrod's Avatar
ccgRAMrod
Bump....
Old Nov 3, 2013 | 09:47 AM
spuldup's Avatar
spuldup
The service manual states the following re: the rack and pinion: "A rack and pinion steering gear is made up of two main components, the pinon shaft and the rack. The gear cannot be adjusted or internally serviced. If a malfunction or a fluid leak occurs, the gear must be replaced as an assembly."
So at least Dodge doesn't endorse any kind of adjustment. As for brands, check out rockauto.com. There are not many shown and they are remans. I have had luck with Cardone before. http://www.cardone.com/Products/Prod...d=22382&p=rock
For the shaft, looks like a $250 part - search "BORGESON 951".
Old Nov 3, 2013 | 11:01 AM
66three83's Avatar
66three83
Don't think the 2500's have rack and pinion!!!!!
Old Nov 3, 2013 | 04:05 PM
Gone Fishin's Avatar
Gone Fishin
You are right! The 2500's have a reticulating ball (I think thats right). The steering gear can be adjusted, but I suggest you follow the FSM on adjustment. As far as a steering shaft, I haven't a clue-----sorry
Old Nov 4, 2013 | 04:33 PM
spuldup's Avatar
spuldup
Wow, my bad big time not looking at the vehicle. Sorry!
Old Nov 6, 2013 | 04:53 PM
Daves69's Avatar
Daves69
evidently something changed in '03...............
http://www.ebay.com/itm/94-02-DODGE-...item5af27284ef
