Air Outlet - Passenger Side
Old Oct 30, 2013 | 01:07 PM
Matthew L Ferguson's Avatar
Matthew L Ferguson
Default Air Outlet - Passenger Side
Does anyone know how to replace the Passenger Side Air Outlet, the one right next to the passenger side door in the dash??
The part is only 20 bucks but the dealership wants $800 to replace it. They say you have to remove the whole dash for this replacement.
Is this True???
Is there a way to remove the dash a little bit and be able to replace this air vent?? There are no good youtube videos that show the passenger side dash removal.
2006 Dodge Ram 3500 Laramie Mega Cab
Need Help
Thanks Matt
Old Oct 30, 2013 | 01:16 PM
abarmby's Avatar
abarmby
Al
Old Oct 30, 2013 | 06:08 PM
66three83's Avatar
66three83
They might be right on that one.
Old Oct 30, 2013 | 06:12 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I'm on my mobile so I can find a lot of things but go through some of my old posts. I posted two links from other (diesel) boards that had a full How To with pics
Old Oct 31, 2013 | 01:25 PM
Matthew L Ferguson
Default Dash Removal Help
WeedaHoe,
Is this the one you are referring too??
http://www.dieseltruckresource.com/d...highlight=hvac
This one has good pictures but it is not the same year and model as might truck.
I have a 2006 3500 Laramie Mega Cab with Dual side Heat.
Still need more Help!
Old Nov 1, 2013 | 11:28 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Try this one
http://www.dieseltruckresource.com/d...d-t210483.html
Old Nov 1, 2013 | 12:14 PM
Matthew L Ferguson
Default Heater Box
Is is possible to take apart the two haves of the Heater box while it is still attached to the firewall?
I would really not like to disconnect the AC lines from the heater box is possible.
Is so, i would try to replace the doors i need to while the dash is pulled back and the heater box is still installed.
Thoughts??
Old Nov 1, 2013 | 12:17 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Maybe the best thing for you to do is download a copy of the service manual and used it as a step by step guide
Also, try this link
http://tinyurl.com/2b6dexh
