Just bought an 03 4.7 that smokes at take off.
Old Nov 30, 2013 | 02:52 PM
projectss's Avatar
projectss
Default Just bought an 03 4.7 that smokes at take off.
Just bought a 03 4.7 auto. That smokes white at take off. Not at idle and it lasts upto about 10 mph. It also has a slight knocking. I was told it was the timing chain tensioner.
Would the white smoke be caused by a bad plenum?
This is my first dodge ever owned.
Thanks
Old Nov 30, 2013 | 04:21 PM
66three83's Avatar
66three83
White smoke=coolant in the combustion chamber. 4.7 with coolant in the combustion chamber=Blown head gasket at least, warped head at worst.
Old Nov 30, 2013 | 04:45 PM
projectss's Avatar
projectss
I havent noticed coolant loss. Oil yes.
But ive only had the truck for 2 weeks.
Its just a little smoke. Atleast its not the rings.
Old Nov 30, 2013 | 04:56 PM
66three83's Avatar
66three83
Well, depending on how cold it is where you are, white smoke is normal when the engine is cold on acceleration. If said smoke smells sweet, it is coolant. Or if the smoke is still present in excess when the engine is warm, it's coolant. The knocking could be the timing, or it could be something else.
Old Nov 30, 2013 | 05:38 PM
projectss's Avatar
projectss
Smells bad. Not sure if sweet. I live in south texas. Super hot down here.
Old Nov 30, 2013 | 07:33 PM
66three83's Avatar
66three83
Texas, huh, well it's not condensation. My money is on head/head gasket.
Old Nov 30, 2013 | 08:11 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Sounds like you bought a headache. Hope you bought it cheap.
Doing a forum or even Google search will yield lots of threads on 4.7s with blown head gaskets with the symptoms of rough idle and smoking (white)
Old Dec 1, 2013 | 11:38 AM
projectss's Avatar
projectss
Not too worried about the head gasket. Aslong as its not the piston rings.
Old Dec 1, 2013 | 11:39 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Piston rings wont be white, it would be blue from oil.
Do a compression test to see what condition your rings and valve train are in
Old Dec 2, 2013 | 06:00 PM
66three83's Avatar
66three83
Not worried about the head gasket? Why?
