tips on rebuilding rear end
Old Dec 29, 2013 | 11:41 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Pinion seal P/N 710481 - $20
Crush sleeve P/N 81059 - $5
OR
you can get the Motive Gear mini install kit (P/N C9.25IK) for $31
this includes Ring And Pinion Installation Kit; Rear 9.25 in. (12 Bolt); Incl. Pinion-Carrier Shims/Pinion Nut/Ring Gear Bolts/Gear Marking Compound/Pinion Seal/Crush Sleeve/Brush/Gasket-RTV
Old Dec 30, 2013 | 05:32 AM
rought's Avatar
rought
When you do your finial back lash adjustment. Use the little holes on each side of the pumpkin at 3.00 and 9.00 o’clock were to cover goes to make your adjustments. Use a small flat head screw driver and a small hammer. because its hard making the finial adjustments from the axel .
Old Dec 30, 2013 | 10:36 AM
gcburkett's Avatar
gcburkett
You probably want to make sure your pinion yoke (flange) is smooth. I had my differential rebuilt at a driveline shop because it was not worth getting all the special tools needed for the amount of labor but I can understand not trusting shops to do the job correctly. If the worn gear pattern looks good I would not change the shim on the pinion. From what I have read changing the gear pattern on used gears causes noise. I would have needed the inch pound torque wrench for measuring pinion preload, a pinion yoke tool, the carrier preload adjuster tools and the dial cage.
Old Dec 30, 2013 | 10:39 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive got all the tools minus the preload wrench which Im making later today. Gear compound is impossible to find locally but I have found an alternative.
Its cold outside today and I really dont feel like doing this but I guess I will have to get to it
Going to pick up my diff/carrier parts from several shops across town here in a few. Of course no one place has everything.
Old Dec 30, 2013 | 10:50 AM
dirtydog's Avatar
dirtydog
Moderate User
Cold out..lol It's like 50*F
People here in NY wear their shorts in those temps..haha Gonna be teens all week and down to -4*F friday night..yikes
Its all relative. I know. I can understand why you want to wear only panties instead of pants to do your install...lmao.
Old Dec 30, 2013 | 10:55 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Panties keep the neighbors away
Old Dec 30, 2013 | 10:56 AM
dirtydog's Avatar
dirtydog
Moderate User
depends on your neighbor...hahahahahaaaa
Old Dec 30, 2013 | 10:58 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
dont tell me you would be looking with binoculars..... LoL
Old Dec 30, 2013 | 11:03 AM
ssbracing's Avatar
ssbracing
Default Quick Question
what is the N08 recall all about?
Old Dec 30, 2013 | 11:04 AM
dirtydog's Avatar
dirtydog
Moderate User
lmao.
ahh no, but there are those that would. just keepin it real is all...
Now back to your rearend..haha
