need help with pcm
Old Jan 3, 2014 | 11:32 AM
green-machinellc's Avatar
green-machinellc
Default need help with pcm
Hey guys I'm curious as to if I fried my com with a jump start. 03 with 4.7l turns over fine, has spark, gauges work, fuel at the rail All plugs hooked up but a no start. Codes showed 685 for asd, so I swapped my asd relay with the wipers relay still no start. I reset the computer with the key in ignition trick. Try to start and no start. Code 685 gone now though so I put in a new crank sensor. Still nothing. Could I have fried computer by jump starting? And how can I check pins at the pcm to make sure power is making it there?
Old Jan 3, 2014 | 11:40 AM
Izero's Avatar
Izero
you might have shorted the battery internally... that is possible..
Disconnect the battery let it sit for a few minutes, reconnect and see what happens.
Try giving the truck a little bit of fuel (step on pedal) while trying to crank if still nothing then try a new battery.
How did the battery get drained? you leave a light on? (if not then there might be another electrical issue causing problems)
Old Jan 3, 2014 | 12:12 PM
green-machinellc
Tried ur tips to no avail, battery was drained by leaving lights on. Also battery is only a few weeks old.
Old Jan 3, 2014 | 12:21 PM
Izero's Avatar
Izero
Pull C-Codes... method is in the link in my signature....
List them exactly as they appear...
The only other thing I can think of as being an issue is the alarm system might have activated itself...
Do you have an aftermarket alarm system or remote start system?
Old Jan 3, 2014 | 12:24 PM
green-machinellc
No alarm not even a factory alarm, codes are 480, 0032
Old Jan 3, 2014 | 12:29 PM
Izero's Avatar
Izero
Those look like P codes (aka DTC's)
Did they show up on the dash just like that or was it like:
4 80
00 32
or
P0480
P0032
Old Jan 3, 2014 | 12:45 PM
green-machinellc
Ya showed up on dash as the p0480
Old Jan 3, 2014 | 12:55 PM
green-machinellc
AA 33
Ac 33
Old Jan 3, 2014 | 01:33 PM
green-machinellc
C codes /\
Old Jan 4, 2014 | 10:39 AM
Izero's Avatar
Izero
Originally Posted by green-machinellc
AA 33
Ac 33
AA PCM messages not received.
AC ABS messages not received.
Check your fuses for the Engine Control and ABS... you might have blown them out...
the P0480 is a cooling fan relay...
All of these point to you shorting something electrically, but I'm really hoping you didn't short the PCM as that would be a very expensive fix.
Can you give us a step by step of how you jump started your truck..?
Anything out of the ordinary happen?
