i may have a short.... HELP
Old Jan 8, 2014 | 08:31 AM
Izero's Avatar
Izero
Originally Posted by MikeHTally
Make sure you disconnect the battery, so you don't trigger the air bag. Let it sit at least two minutes. You'll need a steering wheel puller too, probably.
why??
The IGN switch should be fully serviceable without removing the Steering Wheel.... Now if the problem is the clock spring, then he'd have to remove the steering wheel....
There is actually a youtube video out there somewhere that shows the steps to replace the ignition switch...
Old Jan 9, 2014 | 09:22 AM
Lear70's Avatar
Lear70
Yeah, ditto that, do NOT remove the steering wheel. It's only held in by a few screws once you remove the lower plastic housing.
