2004 5.7 engine hesitation
Old Jan 19, 2014 | 12:09 AM
Decion's Avatar
Decion
Default 2004 5.7 engine hesitation
04 1500 5.7 Hemi. Last weekend I was traveling on the highway, engine started missing and it turned out to be a broken valve spring and bent push rod. Not realizing the extent of the problem I put about 30 miles on the truck before it was at the dealer for service. I have been experiencing some hesitation and an occasional stall at the traffic light. The hesitation occurs under low throttle conditions usually from a stop. Without increasing throttle when it starts to bog down, it seems to bog down for a few revs then jumps on with more power than it should at that throttle position. The problem has slowly been going away, so I am figuring some sensors or plugs were fouled. I checked one plug and it looked good. Any suggestions on a quicker remedy than letting the engine clean itself out? Engine has the power back as the tires chirp when the throttle picks up after the hesitation. I also was able to get 19 mpg on the highway returning after the repair (yes it is the hemi).
Old Jan 19, 2014 | 09:37 AM
MikeHTally's Avatar
MikeHTally
When was the throttle body last cleaned? Might need new plug wires, too. I'd think bad wires would show more at higher rpm, though.
Old Jan 19, 2014 | 02:01 PM
p38251's Avatar
p38251
Start simple.
Old Jan 19, 2014 | 08:43 PM
Decion's Avatar
Decion
Plug wires are original, I know I need to replace at some point, but I don't think they are the source of my current problem.
