Lose Oil Pressure while idling goes up when increasing RPM's
Wondering what could cause this.
I recently did my timing chain and everything is running excellent however over the weekend I began losing all oil pressure when I come to a stop sign or light or get stuck behind traffic and the only way to make it go back up to normal levels is to give it gas.
I changed the oil pressure sensor however this did not solve the problem.
I changed the oil today however I did not have a new filter so I will do that tomorrow.
The oil pump was changed 10,000 miles ago.
Is it possible its just the filter, because it is still happening even with new oil.
Trending Topics
Yeah..... I'd be worried about that too.
Gotta resolve that fast and no more driving before you do I'd suggest.
I'd tee a fitting into the factory sender and fit a mechanical oil pressure gauge.
That would tell you imediately if there's an actual oil pressure problem or an electrical stock sending unit issue. Just fit it temporarily loose in the engine bay for now. Just so you can run the engine and see if the mechanical gauge mirrors what the stock ones telling you.
Can't emphasise enough not to drive it until you know for sure what the fault is.
If the oil pickup is indeed plugged, you won't get any time to save your engine at 3 thousand revs on a highway.
Very expensive repair compared to a little time effort and relatively little money for a mechanical gauge.
Al.
Al.
I don't know whether it applies to your vehicle but 4.7's used to have a problem with a sludge build up. Pull your oil cap off and look at it. If you see a creamy looking buildup on the internal part of the cap you have a sludge problem. One way to treat it is by using Seafoam in your engine oil. You add it to your engine oil just as if you are adding oil, and run the engine for about 20 minutes and then do a complete oil and filter change. This should take care of any internal buildup in the engine and thus avoid having to do a teardown. I myself have never done this but have seen quite a few write-ups of this by a number of people on other forums with good results. Being that I have never done it I cannot be responsible for anything done but you can probably check on you-tube for those that have done it.
